The lens shows quite pronounced barrel distortion at the shortest zoom setting, which however is typical for many standard zooms and thus expected behaviour.
Zooming in, the character of the image distortion soon switches to the pincushion type. At 35mm, the amount is moderate, but increases significantly with longer focal lengths. At 85mm, the lens shows more distortion than what we're used to see from super-zooms.
The good news is that at any focal length distortions are uniform and can easily be corrected by software in post processing (at the expense of resolution and a little field of view, of course).
| 24mm |
35mm |
50mm |
85mm |
The two images below give an impression of the impact of high distortion on real world subjects.
24 mm:
80 mm:
The lens shows quite pronounced light fall-off towards the borders at large aperture settings, especially at the short end of the zoom range. As usual, stopping down helps to reduce the amount of vignetting. At f/8 the remaining darkening should not be an issue for most subjects anymore.
The lens shows excellent resolution in the image center at most tested focal lengths and apertures. Only at its longest focal length the MTF figures decrease a little at the largest aperture setting, but recover to excellent levels by stopping down.
The image borders and corners perform on a lower level, especially at the shortest zoom setting. However, by stopping down it is possible to achieve good to very good resolution across the whole frame.
Chromatic aberrations (color shadows at harsh contrast transitions) are rather high, reaching from slightly above 1.5 pixels at long focal lengths to more than 2.6 pixels at the shortest zoom setting.
