Tamron AF 90mm f/2.8 SP Di macro - Review / Test Report - Analysis |
Canon EOS (APS-C)
As to be expected from a fix-focal lens and especially for a macro lens the level of distortion is absolutely
negligible.
On the EOS 350D with its reduced format (APS-C) the (full format) lens exhibits very little vignetting
at f/2.8 and infinity focus. From f/4 & up it is absolutely negligible. At 1:1 the problem is already non-existent
at max. aperture.
Typical for most macro lenses the Tamron AF 90mm f/2.8 SP Di macro performed very good to excellent in the lab.
The lens is already very good in the center at wide-open aperture with marginally worse corners.
The lens reaches its peak performance at f/5.6 where is scratches the resolution limits of the 8 mega pixel
sensor of the EOS 350D. Beyond f/8 diffraction is the limiting factor - a physical barrier where no smart
lens design can help. Generally you should avoid stopping down beyond f/16.
Similar to most other fix-focal lenses chromatic aberrations (color shadows at harsh contrast transitions) are
very low and usually nothing to worry about.
