Leica Summilux-R 50mm f/1.4 (via adapter on Canon EOS) Review / Test Report - Analysis
Typical for standard/normal lenses the Leica exhibits only a minor degree of barrel distortion (~0.6%) - nothing to worry about under field conditions.
The Leica is a full format lens but regarding its ultra-large max. aperture it still shows some vignetting (0.76EV) at f/1.4 on an APS-C DSLR. However, the problem is already negligible from f/2 onwards.
The Leica shows an impressive although not an unique resolution characteristic in the MTF lab. The center resolution is excellent throughout the tested aperture range. The border performance is good at large aperture but it increases steadily towards medium aperture till reaching an excellent peak performance at f/5.6.
The contrast performance seems to be unusually high even at large apertures - the Zeiss ZF 50mm f/1.4 is quite a bit softer at f/1.4 for instance.
Lateral chromatic aberrations (color shadows at harsh contrast transitions) aren't a strong feature of the Leica (similar to the Canon EF 50mm f/1.2 USM L). At wide-open aperture the problem is quite well controlled but from f/2.8 CAs reach an average width of around 1.2px at the image borders. This can be visible at times.
You may be able to spot some Longitudinal Chromatic Aberrations (LoCA) at large apertures. These are greenish to reddish out-of-focus halos near the in and out-of-focus transitions. This is normal for an ultra-large aperture lens.
