Canon EF 100mm f/2 USM - Review / Lab Test Report - Analysis |
Canon EOS (APS-C)
As expected for a fix-focal lens the level of distortion is absolultely negligible (0.05%).
Things may get a little worse with extreme close-ups.
Vignetting is very well controlled with the lens - at least on an APS-C DSLR.
Wide-open vignetting is just over ~0.5EV which is usually not an issue.
In extremely critical scenes you may stop down a little which immediately
lowers the vignetting to barely measurable levels.
MTF (resolution & chromatic abberations)
The lens delivered a very impressive performance in the lab. The center resolution
is excellent even at wide-open aperture followed closely by the borders which
enter excellent territories from f/4 and up.
It is no problem to use this lens at wide-open aperture which is surely a mainstream
setting for such a portrait lens.
The chromatic aberrations (color shadows at harsh contrast transitions) are exceptionally
low with this lens despite a very slight increase towards medium aperture settings.
The Canon EF 100mm f/2 USM is one of the "can't loose" offers in the Canon lens lineup.
It performed almost flawlessly in all tested categories. It's interesting that the
figures are marginally better compared to its more popular sister lens (EF 85mm f/1.8 USM).
So if you can't or don't want to invest into Canon L glass the EF 100mm f/2 USM is
a pretty obvious solution providing similar qualities at a much lower price. Highly
recommended!
