Sony 70-300mm f/4.5-5.6 SSM G (SAL-70300G) - Review / Test Report - Analysis
Thursday, 24 July 2008 10:00
Typical for most tele zoom lenses the 70-300mm G produces only a low level of distortions. The lens shows slight barrel distortion (~0.4%) at 70mm changing to slight pincushion distortion at 200mm and 300mm (~0.6%). This is nothing to worry about in field conditions.
70mm 200mm 300mm
Thanks to the full format design the amount of vignetting (on APS-C DSLRs) is usually not field-relevant with a max. edge shading of around 0.5EV at 70mm @ f/4.5 and 300mm @ f/5.6.
The Sony 70-300mm G produced very good resolution figures in the MTF lab. The performance is best at 70mm with a generally excellent quality across the image field. There's a slight decrease in performance towards 200mm and more so at 300mm. Unsurprisingly the quality is "worst" at 300mm @ f/5.6. Even so the center resolution is still very high here whereas the borders reach "only" very good (just) levels. Stopping down improves the border quality till reaching its maximum at f/11. The amount of field curvature is negligible.
Below is a simplified summary of the formal findings. The chart shows in line widths per picture height (LW/PH) which can be taken as a quantity for sharpness. The chart is limited to the visually relevant LW/PH range of [850, 2350]. If you want to know more about the MTF50 figures you may check out the corresponding Imatest Explanations.
Lateral chromatic aberrations (color shadows at harsh contrast transitions) are generally well controlled. The problem is a bit more obvious at 70mm from f/8 onwards but other than that the average CA pixel width remains below 1px at the image borders.
Needless to say but you can correct or at least reduce lateral CAs during post-processing e.g. via Photoshop.
