Sony 50mm f/1.4 ( SAL-50F14 ) - Review / Test Report - Analysis
Unsurprisingly the Sony 50mm f/1.4 produces only a marginal degree of barrel distortion - nothing to worry about in field conditions.
The Sony 50mm f/1.4 is a full format lens and as such enjoying the usual sweet spot advantage when used on an APS-C DSLR. At f/1.4 you may experience moderate vignetting (0.7EV) in critical situations but the problem is already negligible by f/2.
Typical for most standard lenses the Sony produces excellent resolution figures EXCEPT at very large aperture settings. At f/1.4 the center resolution is very high but the border performance is rather dismal - same goes for the general contrast which is very low at this setting. At f/2 most of the defects are resolved resulting in an excellent center and very good borders. The peak performance is reached around f/4 where both the center and the borders reach excellent levels. At and beyond f/8 diffraction is limiting factor.
Lateral chromatic aberrations (color shadows at harsh contrast transitions) are not overly well controlled with an average pixel width around 1.4px at the image borders. This is where the rather old design shows up.
The quality of the bokeh, the out-of-focus blur, is naturally of major interest for an ultra-large aperture lens. The Sony lens features a circular aperture shapes which remains intact till just after f/2 - at f/4 the individual aperture blades are getting more obvious. At f/1.4 there's some outlining at the edges of the highlight shapes but this is much better at f/2 and gone by f/2.8. The general blur is somewhat busy at f/1.4 (see also the fence in the sample image section) but improves at f/2 and f/2.8. You may also notice the rather massive amount of longitudinal chromatic aberrations in the cards - more on this in the next chapter.
You can download the full-size images here:
LoCAs (non-coinciding focal planes of the various colors), sometimes called "bokeh CAs", are a further aspect. Similar to most other ultra-large aperture lenses the Sony 50mm f/1.4 has also some stakes here but it's somewhat more pronounced than usual. As you can notice below the halos have different colors - magenta (red + blue) in front the focus point and green beyond. The problem is rather hefty at f/1.4. It decrease slowly the further you stop down but it is still there at f/4.
f/1.4 f/2 f/2.8 f/4
