Cosina AF 100mm f/3.5 macro (Pentax) - Review / Lab Test Report - Analysis |
Macro lenses are designed to produce minimal distortion and the Cosina follows this tradition (0.09%).
The Cosina is a full format lens but it does still produce a moderate amount of vignetting
at f/3.5 and f/5.6. The problem is negligible from f/8 onwards. The marginal decrease
from f/3.5 to f/5.6 is a bit surprising. Regarding the exposure characteristic of the
lens it seems likely that we're probably more talking about f/4.5 rather than the f/5.6
on paper.
The Cosina is able to produce very decent results throughout most of the range.
At f/3.5 the resolution is a bit reduced (still good) at the borders but the center
is already on a high level. At f/5.6 the borders have already improved to very
good quality. The sweet spot of the lens is reached at f/8 with an excellent center-
and very good border-resolution. At f/16 diffraction effects start to have a more
pronounced impact on the quality.
As already hinted in the vignetting chapter the aperture accuracy doesn't seem to
be overly high. The exposure data suggests an effective aperture ~2/3 f-stops
bigger than specified (from f/5.6 onwards).
Please note that this test has been performed at a conventional working distance (~6m).
Dedicated macro tests are NOT possible at this stage!
very low and not really field relevant at all tested settings.
The Cosina performed according to its reputation - "cream in a yogurt cup".
The build quality is dismal but optically it is pretty capable lens when stopped
down a little. Vignetting and CAs are very well
controlled and distortions are absent. It is probably no real competition
for a more "serious" macro lens but if you're on a very tight budget it
is still worth a thought. At around 120€/US$ (or so) it should easily
be able to beat other budget macro solution such as macro diopters, extension
tubes or the popular "pseudo" macro zooms.
| Optical Quality: |
| Mechanical Quality: |  |
| Price/Performance: |  |
