Tamron AF 28-75mm f/2.8 SP XR Di LD Aspherical (IF) (Nikon) - Review / Lab Test Report - Analysis |
The Tamron 28-75mm XR exhibits a medium degree (~1.5%) of barrel distortion at its 28mm setting
changing to minor pincushion distortion at 75mm (~0.4%). At 40mm distortion is marginal. A very
decent performance for a standard zoom lens here.
| 28mm |
40mm |
75mm |
APS-C DSLRs such as the Nikon D200 take advantage of the sweet spot of full format lenses. In this scope
the Tamron produced a very low degree of vignetting throughout the range and
at all aperture settings.
The resolution figures of the Tamron were generally very good to excellent but they were also spoiled
by a centering defect which showed up at large-aperture settings specifically at the wide-end
of the zoom range.
Apart from this performance hit the center resolution of the tested sample was generally
excellent and the borders can follow quite closely. Quite impressive for a lens in this price league.
The lens exhibits a very decent degree of chromatic aberrations (color shadows at harsh contrast transitions).
The average CA pixel width at the borders remain below 1 pixel throughout the tested range so the issue shouldn't
be overly disturbing in field conditions.
The Tamron AF 28-75mm f/2.8 SP XR (forgive me for using a shorter variant of the name ...) proved to be
a very good lens in the lab. The resolution figures are among the highest tested among
the standard zoom lenses - the center resolution is generally excellent and the borders follow closely
on very good to excellent levels.
The distortions are very low as is the amount of vignetting and even CAs are very well under
control. Nonetheless it should be mentioned that this is the 2nd tested sample of this lens and both showed
centering defects - this is worrisome. The build quality of the lens is decent but nothing to rave about.
If you can live with the rather odd zoom range within the APS-C scope the lens is worth a deeper look -
assuming you can get a good sample.
