Voigtlander APO-Lanthar 90mm f/3.5 SL (Nikon) - Review / Test Report - Analysis
Unsurprisingly the Voigtlander produces only a negligible degree (0.2%) of pincushion distortion which is not field-relevant.
The APO-Lanthar is a full format lens and as such it enjoys the usual sweet spot advantage when used on APS-C DSLRs. Within this scope the lens shows only a slight degree of vignetting at f/3.5 and from f/5.6 onwards it's a non-issue.
The Voigtlander is a fairly unambitious lens - it is a moderate tele lens with a comparatively slow max. aperture yet it takes advantage of one "APO" element. Correspondingly the resolution characteristic is on a very high level straight from f/3.5. The center resolution is excellent here and the borders follow on very good levels. At f/5.6 the center reaches its peak and the borders improve to excellent quality. The lens shows its best borders performance at f/8. Diffraction effects reduce the quality from f/11 onwards.
Typical for Voigtlander lenses CAs (color shadows at strong contrast transitions) are basically a non-issue and not field-relevant.
Purple Fringing
The 90mm f/3.5 is not fully resistant against purple fringing (a blooming effect at extreme contrast transitions) although the problem is still comparatively well controlled. Here's a 100% sample crop showing some water reflections:
