Nikkor AF-S 24-120mm f/3.5-5.6G IF-ED VR - Review / Lab Test Report - Analysis
The AF 24-120mm has a rather aggressive 5x zoom ratio so distortion is a little higher than average. Typical for such zooms there is some pronounced barrel distortion at 24mm (2.3%) changing to moderate pincushion distortion (0.9%) towards the long end of the zoom range. At 35mm the lens is basically free of distortion.
24mm:
35mm:
70mm:
120mm:
The AF 24-120mm VR is a full frame lens so on an APS-C DSLR it can take advantage of a sweet spot effect and generally the issue is very well under control. As to be expected the vignetting is most pronounced at 24mm @ f/3.5. At around 0.7EV vignetting may be visible at times but the problem doesn't reach extreme degrees and if needed stopping down helps to reduce the issue significantly.
When following the community discussions around the AF-S 24-120mm f/3.5-5.6G IF-ED VR it doesn't seem to have the best reputation around so I was quite curious whether this would show up in the resolution tests. Mostly it didn't but it's worth to mention that this lens showed an exceptionally even performance without any significant manufacturing flaws whatsoever - one of the very rare golden samples that I've seen so far which is even more surprising regarding its rather complex VR design (VR/IS lenses tend to have more pronounced QC variations).
The center resolution of the lens is excellent throughout the tested focal length range regardless of the chosen aperture (till f/11). At 24mm the border performance can't quite follow at wide-open aperture (quite soft) but from f/5.6 and up the quality level is on a very high level At 35mm the performance is much more harmonic even at f/4. Interestingly there's another drop in border quality at 70mm though the quality remains on a decent level even at f/5.3 (wide-open). At 120mm the resolution characteristic is quite even again. The lens suffers a little from RSAs (residual spherical aberrations) at the wide end of the zoom range whereas field curvature isn't overly pronounced.
All-in-all the results are quite impressive for a 5x zoom here.
Chromatic aberrations (color shadows at harsh contrast transitions) are relatively pronounced at most settings with an average CA pixel width beyond 1px at the image borders. The issue is most pronounced at 24mm with a peak of 1.7px whereas the problem is quite a bit less apparent at 70mm.
The Nikkor AF-S 24-120mm f/3.5-5.6G IF-ED VR showed a quite impressive performance for a zoom lens with a 5x focal length ratio. Apart from a few weak spots the resolution figures are very high and on an APS-C DSLR vignetting is not a big issue. The amount of barrel distortions may be a little objectionable at 24mm (only) and the level of CAs could be a little better. Mechanically the lens is roughly in line with other consumer grade lenses made by Nikon so don't expect a tank-like construction. The VR (Vibration Reduction) is a welcome addition to the feature list as is the very fast Silent Wave AF drive. All-in-all it's a nice package but on APS-C DSLR the focal length range isn't all that great anymore and most users shopping for a new lens will probably prefer to have a look at the new AF-S 18-200mm VR II.
