Nikkor AF-S 24-85mm f/3.5-4.5G IF-ED - Review / Test Report - Analysis |
The AF-S 24-85mm IF-ED shows the typical distortion characteristic of a standard zoom lens
with pronounced barrel distortion at 24mm (2.4%) changing to moderate pincushion
distortion (1.1%) at the long end of the zoom range. At 40mm distortion is marginal.
| 24mm |
40mm |
85mm |
The AF-S 24-85mm IF-ED is a full frame lens so it can take advantage of a sweet spot effect
on an APS-C DSLR. Vignetting is very well controlled indeed with less than 0.5EV at wide-open
aperture throughout the range. This is already rarely field-relevant and even less so at
medium aperture settings.
The lens showed a very pleasant resolution characteristic within the APS-C image
circle. The center performance is excellent and the borders follow
quite closely on a very good level. The sweet spot is at 40mm but the differences
to the other two tested focal lengths is quite marginal.
CAs (color shadows at harsh contrast transitions) aren't all that rosy at 24mm @ f/3.5
with a peak of 2.6px on the average at the image borders. However, stopping down to f/8
helps to reduce the problem to an acceptable degree. At 40mm and more so at 85mm CAs
aren't overly relevant anymore.
Please note that lateral CAs can be corrected quite easily via various tools
such as ACR, RawShooter or Debarrelizer.
The Nikkor AF-S 24-85mm f/3.5-4.5G IF-ED is a very decent standard zoom.
The resolution characteristics is very good throughout the zoom range and
vignetting is very well controlled whereas distortions are
about average for a lens in this class. CAs are a weak spot at 24mm only.
Mechanically it is good quality consumer lens with a fast and near-silent AF.
All-in-all a pretty harmonious package but probably not all that attractive
anymore on APS-C DSLRs where a wide-angle setting of 24mm already tends to
be a little too long for a standard zoom.
