Canon EF 17-40mm f/4 USM L - Review / Test Report - Analysis
Wednesday, 26 December 2007 17:28
At 17mm the lens exhibits quite strong barrel distortion (~2.5%). At 24mm there is very slight barrel distortion whereas at 40mm the problem is negligible.
17mm:
24mm:
40mm:
The chart above has a real-world size of about 120x80cm. Possibly expect more distortions towards closer focus distances.
APS-C DSLRs such as the EOS 350D can take advantage of the sweet spot of full format lenses so vignetting is no big issue with the 17-40mm f/4L here. Surprisingly vignetting is slightly more pronounced at the long end with may be an effect originating in the sensor characteristics.
The EF 17-40mm f/4 L showed an excellent performance in the lab. It's quite safe to assume that the peak performance in the center exceeded the resolution limits of the 8 megapixel sensor of the EOS 350D. The borders are very good though stopping down a little helps to lift up the resolution almost to center quality. It is worth to mention that the extreme borders did not fall apart like e.g. with the Sigma AF 18-50mm f/2.8 EX - that's a plus when using a full frame lens on a DSLR with reduced image circle. The performance peaks around f/8. Thereafter diffraction effects introduce a negative effect (unavoidable).
I should mention that I've used the lens (another sample) during my film SLR days and at the extreme borders the results were somewhat disappointing below 20mm (full format).
Chromatic aberrations (color shadows at harsh contrast transitions) are fairly well controlled for a lens in this class. The problem is somewhat more pronounced at f/4 but stopping down to f/5.6 or beyond reduces the lateral CAs to a low degree.
