Sony 18-70mm f/3.5-5.6 DT ( SAL-1870 ) - Review / Lab Test Report
Typical for many standard zoom lenses the Sony produces quite hefty barrel distortions at 18mm (~3%) which decrease continuously towards the long end of the zoom range where the lens is basically free of distortions.
18mm 24mm 40mm 70mm
Due to its APS-C image circle the Sony 18-70mm produces some vignetting at 18mm and wide-open aperture but generally the issue is surprisingly well controlled for such a lens. At 18mm @ f/3.5 the situation is worst with a vignetting of about 1EV whereas at all other tested settings it is not really a problem anymore.
The Sony 18-70mm f/3.5-5.6 DT produced rather mixed resolution results in the MTF lab. At 18mm the lens is able to provide comparatively decent results with a very high center resolution and good to very good borders. At 24mm the center performance remains very high but the borders quality drops significantly especially when looking at the extreme corners and stopping down doesn't really change the situation. In the medium range (40mm) the performance is decent throughout the tested aperture range. At 70mm there's quite a downtrend again specifically at f/5.6. Stopping down lifts the quality to very good results though. At f/5.6 the contrast level is also just so so here.
The Imatest toolkit had quite some problems to provide reliable resolution results for this lens. Normally CAs are compensated but this Sony lens has rather extreme problems here (see the next chapter). Uncorrected CA can produce a visually softer image so if you prefer to shoot JPEGs straight from the camera the images will certainly look worse than suggested by the charts below.
Below is a simplified summary of the formal findings. The chart shows in line widths per picture height (LW/PH) which can be taken as a quantity for sharpness. The chart is limited to the visually relevant LW/PH range of [850, 2350]. If you want to know more about the MTF50 figures you may check out the corresponding Imatest Explanations.
Lateral chromatic aberrations (color shadows at harsh contrast transitions) are a drastic problem. At 18mm and 24mm the amount of the CAs did not fit into the usually chosen scale thanks to a peak width of up to 4px on the average at the image borders. This is extremely poor. CAs are relatively moderate at 70mm. Please note than lateral CAs can be largely reduced via imaging tools - certainly a good idea here.
For your enjoyment ... here's a 100% border crop of the test chart illustrating the problem:
The Sony 18-70mm f/3.5-5.6 DT is a cheap kit zoom with sells around 100 €/US$ and this is also an indication for what you can expect from this lens. Technically the resolution figures are decent at 18mm and 40mm - less so at 70mm and especially at 24mm. Distortions and vignetting are about in line with the rest of the gang, maybe even slightly better. However, lateral CAs (parasitary color shadows at the image borders) are extremely pronounced with a width up to 4(!)px on the A700. This should be a show-stopper for those who prefer JPEGs straight from the camera because lateral CAs do also reduce the perceived sharpness. This may still have all worked out on the old 6mp DSLRs years ago but on an Alpha 100 and Alpha 700 this is far beyond the edge. Mechanically it is one of the better kit zoom lenses out there but it isn't something to rave about either. If your budget permits you should probably go a little up the food chain and check out lenses like the Sigma AF 17-70mm f/2.8-4.5 or one of the higher grade Sony/Zeiss standard zooms a la Sony 16-105mm f/3.5-5.6 DT.
