Tamron AF 60mm f/2 SP Di II LD [IF] Macro - Review / Test Report - Analysis
With just short of 0.6% the lens shows a slight amount of barrel type distortion. This is a little more than what one would expected from a fixed focal macro lens, however for most usage scenarios this can still be regarded as distortion-free under field conditions (unless for really demanding work like reproduction shots).
(revised) Being an APS-C lens, the Tamron is expected to show some vignetting wide open. A light falloff towards the corners of 1.07 EV is clearly visible in the images, but stopping down helps to reduce vignetting. From f/4 onwards it's no longer field-relevant.
(revised) Macro lenses usually are very sharp and the Tamron 60 is no exception to this rule. Wide open, center and border show very good sharpness, stopped down to f/4 the resolution figures are excellent. The extreme corners follow one step behind with good resolution wide open and very good sharpness at f/2.8 and beyond.
Beyond medium aperture settings diffraction is a limiting factor, but the lens manages to maintain a very high level of sharpness down to its minimum aperture of f/22. It is worth to mention that this latter aspect is odd - the lens performs actually "way too good" at f/22 leading to the conclusion that the effective aperture is actually bigger at small aperture settings, because diffraction effects are usually MUCH more pronounced beyond f/16. The tested sample (multiple ones actually) initially showed an underexposure problem which could support this theory. However, even after successful calibration of the aperture by Tamron the resolution results fully stopped down dropped only slightly (compared to our initial measurement) and still are on a much higher level than expected. Note that the behavior is also different on Canon EOS where the aperture is controlled electronically rather than by a potentially less accurate aperture lever.
The tested sample was well centered.
Please note that the MTFs charts below represent the performance near infinity focus. For the time being macro performance tests are not possible.
(revised) The amount of lateral CAs (color shadows at harsh contrast transitions) is higher than one would expect from a prime lens. With values around 0.8 pixels at the image borders throughout most of the aperture range they are no show stopper, though. In addition, CAs can easily be removed in post processing and some of the newer Nikon DSLRs already do this in camera (if you shoot JPG).
Given the large aperture, the lens qualifies to be used for portraits or similar shots, where subject separation is required. For this kind of shots the quality of the bokeh (the out of focus areas) is of major interest.
Except some nervousness in front of the focus field (which is not really field relevant) the Tamron shows very smooth bokeh and a pleasing softness in out of focus areas. Background highlights show a cat's eye shape wide open towards the image borders, but are rendered circular from f/4 onwards.
LoCAs (non-coinciding focal planes of the various colors) are a common issue with relatively fast glass. As you can notice below the halos have different colors - magenta (red + blue) in front of the focus point and green beyond.
As expected, the lens shows a moderate level of LoCAs wide open and stopping down helps to reduce the fringing considerably. Truly "apochromatic" lenses don't show LoCAs but these lenses are very rare especially below 100mm.
f/2.0 f/2.8 f/4.0 f/5.6 f/8.0 f/11
