Canon EF 85mm f/1.2 USM L - Review / Test Report - Analysis
As expected for a fix-focal lens the level of distortion is negligible:
The chart above has a real-world size of about 120x80cm. Possibly things may get a little worse with extreme close-ups.
An ultra-large aperture lens is expected to vignette quite a bit and at f/1.2 you can indeed see quite pronounced vignetting of about ~0.65 EV even on an APS-C DSLR like the EOS 350D. In many cases this isn't a problem but it can be visible. It's quite save to assume that vignetting is quite a bit more pronounced on an EOS 1D series camera due to the bigger image sensor. On the EOS 350D and at f/1.8 the problem is already quite negligible and at f/2.8 it's basically non-existent.
The lens performed OUTSTANDING in the lab and that's at ALL tested aperture settings. At f/1.2 the results are already very good across the frame which is surprising for such an extreme setting. The performance peaks at f/4-5.6 with resolution figures that suggest that the limits of the 8mp sensor (EOS 350D) are the barrier for this lens.
The chromatic aberrations (CA) don't exceed an average of 0.68 pixels at the image borders so they're quite low and usually no problem. The lens showed slight RSA (focus shift when stopping down - the MTF chart was revised accordingly).
