Canon EF 28mm f/1.8 USM - Review / Test Report - Analysis
The lens showed a slight to moderate degree of barrel distortion (1.2%). Not stellar but pretty good.
On an APS-C DSLR the EF 28mm f/1.8 USM enjoys a sweet spot effect here and at 0.55EV vignetting is very low for such a large aperture lens. This is already very acceptable for the vast majority of field situations. If needed the issue can be basically completely eliminated when stopping down to f/2.8.
Similar to the Sigma AF 30mm f/1.4 EX the Canon lens showed a rather mixed behavior in the lab. The center performance is already high straight from the max. aperture setting peaking in exceptional resolution figures around f/4. Unfortunately the border resolution lacks quite a bit behind. At f/1.8 the borders are very soft. Stopping down help to gradually improve the resolution but even at f/8 the quality does merely exceed very good values. At f/1.8 the lens also suffers from low contrast. This is slightly disappointing for a modern fix-focal lens.
CAs (visible as color shadows at harsh contrast transitions) can reach an average CA pixel width of more than 2 pixels at the image borders - a very weak performance here. CAs can be reduced and usually even eliminated via imaging tools but a fix-focals should definitely perform better than that.
