Laowa 85mm f/5.6 2x Ultra Macro APO - Review / Test Report - Analysis
The Laowa 85mm f/5.6 2x Ultra Macro APO is basically free of image distortions - even without auto-correction (which isn't available with this lens anyway).
The vignetting is fairly uniform across the aperture range with a light falloff of about 1EV (f-stop) at f/5.6 and just slightly less than that when stopped down.
The Laowa lens does a good job in terms of resolution without being able to excel. One reason for this is that the lens is diffraction-limited at f/5.6 already (on high megapixel sensors at least). The typical peak quality on full format cameras tends to be around the f/4 mark and f/5.6 is obviously slower than this. However, the quality is quite uniform between f/5.6 and f/11 with a very good center and a good to the very-good outer image field. f/16 remains usable but f/22 should be avoided. Please note that this is for the quality at conventional focus distances. The results will differ with extreme close-ups but that's nothing we can reasonably test in a formal procedure.
The field curvature is low. The centering quality of the tested sample was Ok. A perfect sample would have probably been a little better at f/5.6.
Lateral CAs (color shadows at the image borders) are very low between f/5.6 and f/11 but increase at f/16 and, more so at f/22. However, the CAs are still moderate even at f/22.
If you are into macro photography it is almost inevitable that most of your scene is blurred due to the shallow depth-of-field. Even the 85mm f/5.6, while not impressive in this respect at conventional focus distances, qualifies here - especially when approaching its max magnification of 2:1 where the DOF is hair-thin. So how is the quality of the bokeh (out-of-focus blur)? It's a bit of a mixed bag.
As you can see below, the highlight rendering isn't really ideal. While circular at f/5.6, the discs become edgy at f/8 already. And the inner zone of the discs is fairly busy.
When looking at the full image field, you have a medium-sized zone in the center where the circular shape is maintained before highlights are transitioning to ellipsoid shapes at the borders and corners. At f/5.6 the overall characteristic is still quite pleasant though. Stopped down to f/8, the outer "discs" look rather distorted due to the combination of the edgy and ellipsoid shape. The "discs" are more uniform from f/11 onward.
While the highlight rendering didn't impress, the quality of the general blur is very smooth in the image background (shown to the left below). The foreground is just a tad less silky but still very good.
Bokeh Fringing / LoCA
Laowa is advertising the lens as an "APO" lens hinting that LoCA (axial CAs) are well controlled. We wouldn't fully sign this off - below is a sample image with crops illustrating that purple/green color fringing is still present at f/5.6.
