Samyang / Rokinon AF 85mm f/1.4 FE - Review / Lens Test - Sample Images & Verdict
Sorry, but just a handful of sample images. Sydney is still in lockdown mode.
MakeSONY
ModelILCE-7RM2
ISO Speed200
Focal Length85.0mm
Aperture:f/2.8
Exposure1/1600s
MakeSONY
ModelILCE-7RM2
ISO Speed200
Focal Length85.0mm
Aperture:f/4.0
Exposure1/2500s
MakeSONY
ModelILCE-7RM2
ISO Speed80
Focal Length85.0mm
Aperture:f/1.6
Exposure1/6400s
MakeSONY
ModelILCE-7RM2
ISO Speed80
Focal Length85.0mm
Aperture:f/1.6
Exposure1/8000s
Competition
There are currently three 85mm f/1.4 AF lenses available in E-mount, the Samyang AF 85mm f/1.4 FE (to the left below), the Sony 85mm f/1.4 GM (center), and the Sigma 85mm f/1.4 DG DN (right) - and they all reside in their very own pricing slot with roughly a 500USD/EUR distance between the Samyang and the Sigma, and the Sigma and the Sony. This is already making clear that the Samyang lens is the value king here. If photography is just a hobby for you, the Sony GM lens is "a bit" over the top. It may have a certain edge here and there - specifically regarding toughness - but spending an extra grand for this requires quite some enthusiasm ... or the ability to tax-deduct the costs. We haven't tested the Sigma lens yet - but we have little doubt that it is better than the Samyang, and it has certainly better sample consistency and after-purchase service. Still, it's much more expensive.
The Samyang AF 85mm f/1.4 FE has been substantially improved compared to the older DSLR variant. The resolution is still not impressive at f/1.4 but fit-for-purpose if you intend to use it for portraits. You just may not want ultra-sharp results in this case. However, if needed the Samyang can give you that when stopping down a bit. The quality is already very high at f/2 and downright great at medium aperture settings. Image distortions are a non-issue even in RAW files. Typical for such lenses, the vignetting is a bit on the high side at f/1.4 but most users will probably rely on auto-correction which reduces the light falloff to an acceptable level. From f/2 there isn't anything to worry about here. Lateral CAs are low. The same can't be said about axial CAs (LoCAs) which can be very pronounced in certain scenes. Axial CAs are very difficult to remove in post-processing. The quality of the bokeh is pretty good overall. The general quality of the out-of-focus blur is pretty silky, especially in the critical background. Out-of-focus highlights are very nicely rendered in the image center but the circular shape is falling apart rather rapidly beyond.
In terms of build quality, it is the best Samyang lens that we tested to date - the metal body feels very sturdy and Samyang implemented some degree of weather sealing. An internal focusing mechanism is also maintaining a constant lenght throughout the focus range. The AF is not the fastest around though. It has to shift quite some weight due to the heavy glass elements but there's room for improvement here. The rather noisy aperture mechanism isn't ideal either.
The few weaknesses have to be balanced with the price tag of the lens and the Samyang AF 85mm f/1.4 FE is hard to beat in this respect - a true value king.
