Samyang AF 50mm f/1.4 FE - Review / Test Report - Sample Images & Verdict
MakeSONY
ModelILCE-7RM2
ISO Speed640
Focal Length50.0mm
Aperture:f/4.0
Exposure1/60s
MakeSONY
ModelILCE-7RM2
ISO Speed100
Focal Length50.0mm
Aperture:f/2.8
Exposure1/1000s
MakeSONY
ModelILCE-7RM2
ISO Speed100
Focal Length50.0mm
Aperture:f/1.4
Exposure1/8000s
MakeSONY
ModelILCE-7RM2
ISO Speed100
Focal Length50.0mm
Aperture:f/11.0
Exposure1/160s
MakeSONY
ModelILCE-7RM2
ISO Speed100
Focal Length50.0mm
Aperture:f/11.0
Exposure1/125s
MakeSONY
ModelILCE-7RM2
ISO Speed100
Focal Length50.0mm
Aperture:f/4.0
Exposure1/250s
MakeSONY
ModelILCE-7RM2
ISO Speed100
Focal Length50.0mm
Aperture:f/10.0
Exposure1/100s
MakeSONY
ModelILCE-7RM2
ISO Speed100
Focal Length50.0mm
Aperture:f/10.0
Exposure1/200s
MakeSONY
ModelILCE-7RM2
ISO Speed100
Focal Length50.0mm
Aperture:f/5.6
Exposure1/1250s
MakeSONY
ModelILCE-7RM2
ISO Speed100
Focal Length50.0mm
Aperture:f/5.6
Exposure1/640s
MakeSONY
ModelILCE-7RM2
ISO Speed100
Focal Length50.0mm
Aperture:f/1.4
Exposure1/1000s
MakeSONY
ModelILCE-7RM2
ISO Speed100
Focal Length50.0mm
Aperture:f/2.0
Exposure1/5000s
MakeSONY
ModelILCE-7RM2
ISO Speed64
Focal Length50.0mm
Aperture:f/11.0
Exposure1/160s
MakeSONY
ModelILCE-7RM2
ISO Speed400
Focal Length50.0mm
Aperture:f/1.4
Exposure1/80s
MakeSONY
ModelILCE-7RM2
ISO Speed100
Focal Length50.0mm
Aperture:f/4.0
Exposure1/1250s
Competition
The Samyang AF 50mm f/1.4 FE (left) has two main competitors at the time of this review - the Zeiss Planar T* FE 50mm f/1.4 ZA as the Sigma 50mm f/1.4 DG HSM ART. We haven't tested the Zeiss lens yet but it has a very good reputation. And it better should be excellent regarding its excessive price tag. The Sigma lens resides just above the Samyang lens in terms of pricing. It's a bit of an odd lens because it's actually based on the DSLR variant and was merely adapted to Sony FE mount by extending the lens barrel. Still - it's better than the Samyang but besides being longer, it's also substantially heavier.
The Samyang AF 50mm f/1.4 FE is a bit of a disappointment. It's not exactly a small lens and it's obvious that Samyang spent some efforts designing it but the performance is just not good enough for a high-resolution sensor. The center quality is fine but the resolution falls apart towards the outer image field at large-aperture settings. Conversely, the results are great at medium apertures but that's not the sole reason for buying such a lens. To be fair, however - in real life this may not be that much of an issue. How often do you require sharp corners at f/1.4 or f/2 after all? Lateral CAs are low - at the borders at least - whereas axial CAs are very pronounced. The native image distortion is very low. The vignetting is taken care of by image auto-correction. In RAW mode, the light falloff is high at f/1.4 though. The quality of the bokeh has two sides. Highlights are nicely rendered in the center zone, less so in the corners. The rendering of the general out-of-focus blur could be better in the background.
The build quality is impressive but stays just short of professional-grade expectations. Namely, weather-sealing is absent. That being said the all-metal construction is solid. The AF speed is quite fast and it's near-silent. While the focus ring is very smooth to handle, the actual focusing is a bit on the coarse side in manual (by-wire) mode.
Overall we are not convinced that the Samyang AF 50mm f/1.4 FE is a good choice in this class. That's, of course, easily said given the price tag of the Sony/Zeiss alternative. If you are on a budget and can stand the weight, maybe consider the Sigma 50mm f/1.4 DG HSM ART or settle for something slower like the Zeiss Sonnar T* FE 55mm f/1.8 ZA.
