Pentax SMC-FA 100mm f/2.8 macro - Review / Lab Test Report - Analysis |
Macro lenses are designed to produce minimal distortion and the Pentax SMC FA 100mm f/2.8 macro
does certainly qualify here (0.02%).
As a full format lens the FA 100mm f/2.8 enjoys a sweet spot advantage on the K10D.
At f/2.8 the problem is slightly more pronounced but even here the level of vignetting
shouldn't be really field-relevant. From f/5.6 the problem is hardly detectable
anymore.
The FA 100mm f/2.8 macro produced very high resolution figures in the MTF lab.
The resolution is already very good and exceptionally even at f/2.8. Stopping
down does only result in a marginal improvement although a slight peak is
reached at f/8 with an excellent center to border quality (just). Beyond f/8
the lens runs into the usual and unavoidable diffraction problems. At f/22 the
resolution is still amazingly high - actually too high in relation to the
diffraction problems at this setting. The nominial aperture (f/22) is probably
larger than the effective one. At f/32 there's only the typical image soup left.
The contrast level of the FA 100mm f/2.8 macro seems a bit lower compared to
other lenses in this lens class.
Please note that this test has been performed at a conventional working distance (~6m).
Dedicated macro tests are NOT possible at this stage!
low and generally not field relevant at all tested settings.
The Pentax SMC-FA 100mm f/2.8 macro is an very good lens without significant
weaknesses. The resolution level is very high (although not exceedingly so) from
f/2.8 all the way down to f/22 (nominal, the effective aperture is probably larger).
Distortions are absent and CAs are not field-relevant. Same goes for vignetting.
Thanks to a metal body and tight tolerances the build quality of this old lens
is excellent.
| Optical Quality: |  |
| Mechanical Quality: |  |
| Price/Performance: | discontinued |
