Sigma AF 150mm f/2.8 APO EX HSM macro DG D - Review / Test Report - Analysis
Macro lenses are renowned for minimal distortions and the 150mm f/2.8 APO EX is no exception here - the degree of distortions is absolutely negligible.
As mentioned above the Sigma is a full-format lens so the D200 can take advantage of a sweet spot effect here. At infinity focus and f/2.8 a slight degree of vignetting may be visible in critical scenes whereas onwards from f/4 the issue is negligible. At close focus distances the issue is less pronounced even at f/2.8.
Typical for most macro lenses the resolution of the Sigma AF 150mm f/2.8 APO EX macro DG D is excellent straight from the max. aperture setting. The peak performance is reached at f/5.6 with absolutely superb quality figures. All-in-all the Sigma is able to match the performance of the recently reviewed Micro-Nikkor AF-S 105mm f/2.8G IF-ED VR. The tested sample suffered a bit from a slight centering defect which shifted the quality center a little below the geometrical image center.
The Sigma is also compatible to the two Sigma APO EX DG tele-converters. When combined with the 1.4x (= 210mm f/4 or a "310mm" equivalent) the quality decreases by about one "school mark" to very good quality levels across the tested aperture range.
Please note that the MTFs charts below represent the performance near infinity focus. For the time being dedicated macro performance tests are not possible.
Below is a simplified summary of the formal findings. The chart shows in line widths per picture height (LW/PH) which can be taken as a quantity for sharpness. The chart is limited to the visually relevant LW/PH range of [750, 2250]. If you want to know more about the MTF50 figures you may check out the corresponding Imatest Explanations.
Chromatic aberrations (color shadows at harsh contrast transitions) are very well controlled with an average CA width of less than 0.6px at the image borders. Surprisingly there´re even less CAs when combining the lens with the Sigma AF 1.4x APO EX DG tele converter.
