Vintage Lens Test: Asahi Pentax SMC Takumar 105mm f/2.8
Review by Klaus Schroiff, published February 2023
Welcome to our new mini-series of vintage lens tests - and this time, it's not just about some vintage-style lenses but truly about lenses from the 1970s to the early 1980s. In phase I, we'll have a look at lenses around the 100mm f/2.8 mark with a typical used-market value between $100 to $200. This is probably the financial sweet spot for vintage lenses that you don't just want to collect but intend to use. There are substantially more expensive (and better) lenses from this era but you have to be quite an enthusiastic believer in this case. Thus let's keep more ground contact here. Our 1st "victim" is the Asahi Pentax Super-Multi-Coated Takumar 105mm f/2.8. We believe that this specific type was manufactured between 1971 and 1974. Depending on the source, there were 3-5 different variations of this lens. This is a "late" model of the series.
Some readers may wonder about the "Asahi" in the name. Asahi Pentax was a brand owned by Asahi Optical Co., Ltd, which is now simply known as Pentax. The company was founded as "Asahi Kogaku Goshi Kaisha" in 1919 in Japan and produced a wide range of camera equipment, including 35mm film cameras, medium format cameras, and lenses. One of the most famous and popular camera models of Asahi Pentax was the Spotmatic, which was introduced in 1964 and was one of the first cameras to use a through-the-lens light meter to determine the correct exposure. Eventually, Asahi Optical Co. Ltd was renamed Pentax Corporation - surprisingly, as late as 2002.
The build quality of the Asahi Pentax Super-Multi-Coated Takumar 105mm f/2.8 is positively old school, meaning that the lens body is fully made of metal. The focus ring operates as smoothly as silk - probably the best mechanical focus feedback that we ever experienced at OpticalLimits. The clicked aperture ring also screams quality. If you didn't know that the lens is 50 years old, you wouldn't believe it (we got a sample in mint condition). Another astonishing realization is the size of the lens. A modern 100mm lens isn't big, but the Pentax lens is tiny. Unfortunately, this applies to the naked lens only. It has an M42 screw mount, and with the added M42-to-E-mount adapter, it loses some of its appeals. There are, of course, several aspects where you can notice its age. The inner lens tube extends when focusing towards shorter focus distances, and there is no formal weather-sealing at all. The M42 mount also means that you can quickly change to another M42 lens just like this - having a screw mount basically means that it has to have its own adapter when using it on today's cameras.
The optical design is almost a curiosity by modern standards - 5 elements in 4 groups. Just for comparison: A modern equivalent is the Sigma 90mm f/2.8 - with 11 elements in 10 groups, including no less than 5 special glasses. Different eras have different tech and different priorities. Back in the day, optical designers tried to minimize the number of optical elements for better flare resistance, for instance.
Needless to say - it's a fully manual lens. Thus you set the aperture on the lens while (usually) setting the camera to aperture priority mode. Manual focusing is pure joy with this lens, and when using a magnified view, it's also precise. It does slow you down, but that's more part of the fun of using a vintage lens.
Optical construction5 elements in 4 groups
Number of aperture blades6
min. focus distance1.20m (max. object magnification 1:9.1)
Dimensions57x63mm
Weight278g
Filter size49mm
Hoodoptional, barrel-shaped
Other features-
MountM42
Back in the day, there was no image auto-correction, of course, thus designers had to optimize the real thing. The 105mm f/2.8 shows just a bit of pincushion distortion which usually goes unnoticed.
The vignetting is also very moderate with a light falloff of ~0.8EV (f-stops) at f/2.8. At f/4, the vignetting is negligible already.
MTF (resolution @ 42mp on Sony Full Format)
I reckon most of you are interested in how a 50-year-old lens performs on a high-megapixel full-format sensor (here: at 42mp). Well, the SMC Takumar 105mm f/2.8 struggles quite a bit. The center quality is actually pretty good at f/2.8 although the contrast level is much reduced. The outer image field is a different story though. Or in other words - it's extremely soft here. Stopping down to f/4 improves the center quality and especially the contrast level whereas the borders/corners are still unimpressive. This changes at f/5.6. The broader center is very good followed by good borders and just the extreme corners remain quite soft. They finally improve to good levels at f/8. f/8 is also the sweet spot of the lens. f/11 remains decent although diffraction takes its toll here.
The field curvature is low. The centering quality of the tested sample was good.
Lateral CAs vary slightly with a typical average pixel width of 0.8px at the image borders. This is actually pretty good.
If you purchase a vintage lens you tend to do it either for budget reasons or because you are after a special character of a lens. The SMC Takumar 105mm f/2.8 has certainly some of the latter with respect to its bokeh.
Out-of-focus highlights show a very pronounced outlining at f/2.8 - or in other words: it bubbles. The inner zone of the discs is very smooth though. Stopping down to f/4 eliminates the outlining effect but you can clearly see the very edgy aperture shape, more so at f/8.
Despite the tiny front element, there doesn't seem to be too much mechanical vignetting. The highlight discs are broadly intact across the image field - we have seen a lot worse in modern lenses lately. Stopping down to f/4 results in an even more uniform highlight shape - albeit an edgy one as mentioned before.
The quality of the general blur in the focus transition zone is great in the background (shown to the left). The foreground blur is somewhat hazy though.
Bokeh Fringing / LoCA
Without revealing too much but this aspect is the one where most of the vintage lenses are struggling. As you can see below, the axial CAs are massive at f/2.8, especially in the foreground. It's not all that extreme anymore at f/4 and mostly gone from f/5.6 onward.
We'll post a couple of sample images at a later stage. This is a very time-consuming aspect and vintage tests are just 2nd class citizens for obvious reasons.
The Asahi Pentax SMC Takumar 105mm f/2.8 isn't a hidden gem among vintage lenses. However, it still has its merits. In terms of resolution, you shouldn't expect too much - especially on a high-megapixel full-frame sensor. The center resolution is actually pretty decent at f/2.8 but the contrast level is low and the outer image field is plain soft. The overall quality is pretty good at f/8 but that's not a miracle really. Image distortions and lateral CAs are very low. This can't be said about axial CAs (LoCA) which are quite extreme. If you are looking for a special vintage character you may find it in the bokeh. The Takumar produces highlight bubbles at f/2.8 and the highlight discs are actually pretty nice across the image field. The out-of-focus background blur is also very smooth.
More so than the image quality, the primary joy of using this lens comes from its build quality. The metal body and buttery smooth control rings are simply superb. It's just something that you will appreciate immediately. Don't expect modern features such as weather sealing, of course. Needless to say, this is also a fully manual lens with all the pros and cons that come with it.
It's not surprising that these old Asahi Pentax SMC Takumars have many fans out there. They offer a true vintage feel - more so than some other oldies that we have tested. In terms of sheer optical performance, you should lower your expectations though - at least with respect to the Asahi Pentax SMC Takumar 105mm f/2.8. It may be Ok on a 24mp body but higher megapixel cameras are a bit too much for it really. If you are just into 4K video (=8.3 megapixels) you can relax, of course - you can almost mount a coke bottle and still get sharp results.
